Material
Analysis > Property > Material
Introduction
The Material has secondary ribbon, which consists of the following tools:
Note: For more details on Material, please refer to Material.
Note: For more details on the mathematical and physical aspects of Flux materials models, please refer to Available Materials in Electromagnetic Solutions.
Materials already created by default
There are already some materials created by default in a new SimLab project (.slb project).
Note: If you reopen an existing SimLab project, then these predefined materials will disappear if they were not assigned to bodies.
We can see the materials, in the Property Browser (5th tab):
Here are the characteristics of the 4 predefined materials having magnetic properties:
  • 3 Solid Materials: Aluminium, Cast Iron and Steel
    Aluminium Cast Iron Steel
    Magnetic Properties Type: Soft Magnetic Type: Soft Magnetic Type: Soft Magnetic
    BH model: Analytical (Linear) BH model: Analytical (Nonlinear) BH model: Analytical (Nonlinear)
    Saturation set False Saturation set True Saturation set True
    - Knee adjustment set True Knee adjustment set True
    Relative permeability: 1 Initial relative permeability: 16108.8 Initial relative permeability: 2022.68
    Saturation magnetization: 1.98809 T Saturation magnetization: 1.9 T
    Knee adjustment coefficient: 4.84016 Knee adjustment coefficient: 0.933609
  • 1 Fluid Material: Air
    Air
Create Materials
In order to create materials, In the Analysis ribbon click on click on Material and click on Create .
It opens the Create Material dialog box:
You can create 2 different types of magnetic materials:
  • either Hard Magnetic in MS 2D and 3D and MT 2D and 3D (but not in MAC 2D and 3D):
    For the BH model, there are 3 models available:
    • if you choose a Linear BH model, then you will have to define:
      • Remanent flux density Br
      • Normal coercivity HcB
      • Thermal dependence (optional)
      → the Transversal relative permeability μr = Br/(μ0*HcB) is computed automatically and the value is displayed without the possibility to modify it
    • if you choose a Nonlinear BH model, then you will have to define:
      • Intrinsic coercivity HcJ
      • Transversal relative permeability µr
        • Automatically computed through Br and HcB: μr = Br/(μ0*HcB) → is computed automatically and the value is displayed without the possibility to modify it
        • User-defined
    • if you choose a Nonlinear with knee adjustment BH model, then you will have to define:
      • Initial relative permeability
      • Knee adjustment coefficient a
        • User-defined
    • if you choose a Raw data BH model, then you will have to define:
      • Points of the BH data or import a .csv file or a .txt file or a .dat file
      • Model in third quadrant: Linear or Symmetrical
  • or Soft Magnetic:
    • if you choose a Analytical BH model, then you will have to define:
      • Relative permeability µr
      • Saturation set False for a linear model
      • Iron losses computation : none or Bertotti model
        • Temperature exponential constant C
        • Curie temperature Tc
      • Saturation set True for a nonlinear model
        • Saturation magnetic polarization Js
        • Knee adjustment
          • false: (without knee adjustment)
          • true: set a value
    • if you choose a Raw data BH model, then you will have to:
      • define the points of the BH data or import a .csv file or a .txt file or a .dat file
About Iron loss
Note: In MT 2D and 3D and in MAC 2D and 3D, it is possible to specify a model to compute the iron losses. Only modified Bertotti model is available at this time, characterised by 3 coefficients and 3 exponents:
  • k 1 is the hysteresis losses coefficient;
  • k 2 is the classical losses coefficient;
  • k 3 is the excess losses coefficient;
  • α 1 is the hysteresis losses exponent;
  • α 2 is the classical losses exponent;
  • α 3 is the excess losses exponent.
A material with modified Bertotti model is needed to compute iron losses in a Sheet Lamination part.
About Thermal properties
For electromagnetic analysis thermal properties can be defined for:
  1. Electrical properties:
    In case of electrical properties, temperature dependence can be defined for the electrical resistivity. Here the electrical resistivity is defined as a linear function of the temperature.
  2. Magnetic properties:
    1. Permanent magnet: For permanent magnet material thermal properties can be defined for only the linear BH curve type. For such a type of material the Remanent Flux density (Br) can be defined as a linear function of the temperature.
      Note: For other BH curve type Nonlinear and Spline, thermal properties cannot be defined in the current SimLab version.
    2. Soft Magnetic material: In the case of soft magnetic materials, thermal properties can be defined for non-linear BH curve type. In this case the B(H) behaviour law is defined as an exponential function of the temperature.
Warning: The working temperature of the bodies should be defined using the Temperature. For more information, please see Temperature.
Steps for creating materials
  1. Click on the Create
  2. Enter a name for the material.
  3. You can keep the default values in the 4 following fields:
    • Material ID
    • Category: Solid
    • Class: Metal
    • Model: Isotropic
    Note: This information has no impact on the electromagnetic simulation.
  4. Define magnetic properties: Magnetic Properties.
  5. Enter the characteristics of the material.
  6. Click on the OK button.
    The material is created.
    You can see it in the Property Browser (5th tab).
    Note: The following step is: Assign materials to bodies
Open the Material Database manager
In order to open the material database manager, click on the Built-in DB
It allows to open:
  • the SimLab Material Database
    You can import materials from the predefined SimLab Material Database into the SimLab project using the Load to Material Browser button.
    This database contains many materials of electric, hard magnetic and soft magnetic types.
  • a User Material Database if you have already created one
    You can import materials from a User Material Database into the SimLab project using the Load to Material Browser button.
    You can modify the material properties using the Update Database button.
Open the AMDC Material Database manager
In order to open the Altair Material Data Center (AMDC), click on the AMDC
It allows to open:
  • the Altair Material Data Center (AMDC)
    Altair Material Data Center (AMDC) is allowing you to choose best suited material from the huge collection of material from trusted suppliers. It permits search, compare data, and plots the material parameters using different filters like material type, provider, physics type.
    SimLab provide the direct access to the AMDC, to download the appropriate material for multi physics solutions.
    You can download materials from AMDC by following the steps below:
    1. Select the required material.
    2. Go to CAE Model tab, then click on "Save to My material" option.
    3. Now the material added to the SimLab material browser.
    4. The downloaded material will be retained in the subsequent databases.
    5. Use "Reset Remembered Materials" in Material right click menu to delete the downloaded materials.
For example, in our contactor project, here is the material assignment to the bodies:
Note: For the coils, there is no need to assign any material.
There are 3 possibilities to assign materials to bodies:
  1. In the Create Material window:
    After having entered the material properties, you can select the body which is composed of this material (the outline of this body is displayed in red), and then click on the OK button.
  2. In the graphic window:
    After having created the materials, select the body you want to assign a material to (the outline of this body is displayed in red), then right-click and select the contextual menu Material and then select the wanted material.
  3. In the Assembly Browser (1st tab):
    1. Display the Material column:
      Right-click on the Name column title bar then check Material and then click on the OK button.
    2. Assign the material to the body:
      After having created the materials, in the column Material and in front of the body (of the .gda model), left-click and then select the material you want to assign to this body.
Tip:
In the Property Browser (5th tab), right-click on a material and the 2 contextual menus Select Entities and Hide Entities allow you to select and hide the bodies assigned to a material.
