Available Materials in Electromagnetic Solutions
Introduction
The solving of an electromagnetic problem consists of solving a set of equations:
  • the Maxwell equations, which represent the backbone of the theory
  • the constitutive equations of the matter, which model the material properties.
Material Constitutive equation Material property
magnetic μ: permeability (H/m)
dielectric ε: permittivity (F/m)
electric/conductive ρ: resistivity (Ω.m)
σ: conductivity (Ω-1.m-1)
Soft Magnetic Material
Model Formula Parameters
Linear isotropic Soft Magnetic
Analytical BH model
B= μ.H μr: initial relative permeability
Nonlinear isotropic saturation (analytic with knee adjustment)* Soft Magnetic
Analytical BH model with Saturation
B= μ(H).H
Js: saturation magnetization (T)
a: adjustment coefficient of the B(H) curve knee
Nonlinear isotropic saturation (spline) Soft Magnetic
Raw data BH model
B= μ(H).H list of coordinates of points (H,B)
Note: In MT 2D and 3D and in MAC 2D and 3D, it is possible to specify a model to compute the iron losses. Only modified Bertotti model is available at this time, characterised by 3 coefficients and 3 exponents:
  • k 1 is the hysteresis losses coefficient;
  • k 2 is the classical losses coefficient;
  • k 3 is the excess losses coefficient;
  • α 1 is the hysteresis losses exponent;
  • α 2 is the classical losses exponent;
  • α 3 is the excess losses exponent.
Note: A material with modified Bertotti model is needed to compute iron losses in a Sheet Lamination part.
Hard Magnetic Material
Warning: In MAC 2D and 3D, Hard Magnetic material cannot be used.
Linear magnet described by the Br module* Hard Magnetic
Linear
B= [μ].H + Br μr//: relative permeability (recoil line slope)
Br: remanent flux density (T)
Nonlinear magnet described by Hc and the Br module * Hard Magnetic
Nonlinear
B= [μ(H)].H + Br μrmax: maximal relative permeability
μr⊥: transverse relative permeability
Nonlinear magnet described by spline Hard Magnetic
Raw data
Dielectric Material
Linear Isotropic Dielectric properties → Linear D = ε0εrE εr: relative permittivity
Isotropic Spline Dielectric properties → Spline
Electric Material
Linear Isotropic resistivity* Electric properties → Electric resistivity J = (1/ρ)E ρ: electric resistivity
Note: the * indicates the possibility to use this material model depending of the temperature
