Define Particles
The Define Particles tool allows you to create particles under a bulk material created in SimLab.
The user can specify the shapes of the particles using any of the following method.
Select body:
- User can select a body (either CAD / FEM / STL / OBJ) to define a particle shape.
Select shapes:
- User can define a particle shape by selecting a shape and modify the sizes from Select shapes dropdown.
Custom Spheres (choose from Select shapes dropdown):
- User can define a particle shape by specifying multiple spheres data
(position and radius)
Note:
- Particle shape and its post processing support:
S. No Shapes Post Processing Support 1 Single sphere yes 2 Dual sphere yes 3 Triple yes 4 Square Four Sphere yes 5 Straight Four Sphere yes 6 Tetrahedral Four Sphere yes 7 Cuboid yes 8 Triangular Pyramid yes 9 Prism yes 10 Sphero Cylinder No 11 Custom Sphere yes 12 Custom Shapes (Select body) yes - User can preview the particle shapes during creation (except Cuboid, Triangular Pyramid, Prism and Sphero-cylinder).
