Import CAD
Import CAD is a common feature for several electromagnetic solutions:
| Import CAD | MS | MSIM | MT | MAC | ES | PE | SC |
| 2D | - | - | - | ||||
| 3D |
The documentation is common for all these EM solutions.
Introduction
CAD files like Parasolid, STEP, CATIA, Creo, JT, NX, SOLIDWORKS, Inventor, ACIS, AutoCAD and ECAD can be imported directly into SimLab without any data loss. Also, CAD files can be translated into Parasolid or STEP.Parasolid
This option is used to import Parasolid files with extension *.xmt_txt, *.x_t and *.x_b.Refer the following link to know more about the various Parasolid import options.
STEP
STEP files with extensions *.stp and *.step can be imported into SimLab.Refer the following link to know more about the various STEP import options.
CATIA
This option is used to import CATIA files with extensions *.CATPart and *.CATProduct. Refer the following link to know more about the various CATIA import options.Creo
This option is used to import Creo part and assembly files with extensions *.prt and *.asm. Creo import allows the user to specify Body type, Entities (Co-ordinates or Datum points), Design parameters, Instance of a part, Simplified presenattion, Geometric approximation (Exact Geom or Facets) and Import Assembly Structure.Refer the following link to know more about the various Creo import options. SimLab supports following Creo versions.
- Creo 2.0
- Creo 3.0
- Creo 4.0
- Creo 5.0
- Creo 6.0
- Creo 7.0
- Creo 8.0
JT
This option is used to import JT files with extension *.jt written out from various modeling softwares.Refer the following link to know more about the various JT import options.
NX
This option is used to import NX files with extension *.prt. NX import allows the user to specify Units, Body type, Groups and Import Assembly Structure.Refer the following link to know more about the various NX import options.
SOLIDWORKS
This option is used to import SOLIDWORKS files with extension *.SLDPRT and *.SLDASM.Refer the following link to know more about the various SOLIDWORKS import options.
Inventor
This option is used to import Inventor files with extension *.ipt and *.iam.Refer the following link to know more about the various Inventor import options.
ACIS
This option is used to import ACIS files with extension *.sat.Refer the following link to know more about the various ACIS import options.
AutoCAD
This option is used to import AutoCAD files with extension *.DXF and *.DWG.Refer the following link to know more about the various AutoCAD import options.
ECAD
This option is used to import Electronics CAD or ECAD files with extension *.tgz, *.tar, *.zip, *.pcb, *.pcbdoc, *.xml and *.cvg.Refer the following link to know more about the various ECAD import options.
Altium
This option is used to import Altium ECAD files with extension *.pcb and *.pcbdoc.
IPC-2581
This option is used to import IPC-2581 ECAD files with extension *.xml and *.cvg.
Translate to Parasolid through Spatial
Various CAD format files are converted into Parasolid file using the Spatial Translator and then the converted Parasolid file is imported into SimLab.
Translate to Parasolid through CT
Various CAD format files are converted into Parasolid file using the CT translator and then the converted Parasolid file is imported into SimLab.
