Surface Mesh
Surface Mesh is a common feature for several electromagnetic solutions:
| Surface Mesh | MS | MSIM | MT | MAC | ES | PE | SC |
| 2D | - | - | - | ||||
| 3D |
Note: The documentation can be found:
- for the 3D Magnetic solutions (Magnetostatic, Transient Magnetic, and AC Magnetic): see Surface Mesh - 3D Magnetic Solutions
- for the Magnetostatic Integral solution: see Surface Mesh - MSIM
- for the 2D Electrostatic solution: see Surface Mesh - ES2D
- for the Parasitics Extraction solution: see Surface Mesh - PE
- for the AC Supplied Conductors solution: see Surface Mesh - SC
- for the other EM solutions: see Surface Mesh
