Mesh Patterns Mesh Control
The manner in which elements are arranged in a face are known as mesh pattern.
Following are the three types of mesh pattern,
- Iso Mesh
- Free Mesh
- Union Jack
- Aligned Mesh
Iso Mesh
This create elements that have 2 edges almost 90 degrees and the diagonals are inclined in the same direction. This isomesh pattern can be created on a four sided surfaces.
Free Mesh
Union Jack
This create elements that have two edges almost 90 degrees and the diagonals are inclined in the opposite direction.
Aligned Mesh
All the elements in the selected faces will get aligned to a certain direction. This can be applied to any face.
