Transfer
Dialog Box
Mesh controls can be transferred between selected bodies in “From bodies” to “To bodies”. It is used to transfer mesh control from CAD bodies to CAD/FEM bodies.
Cad IDMesh controls will be transferred using Cad ID. It supports only Cad-Fem transfer.
Matching facesMesh controls will be transferred based on matching/identical entities. It supports both Cad-Fem and Cad-Cad transfer.
Tolerance
The identical entities are identified using the specified tolerance value and it is used only for the “Matching faces” method. The average element size of the selected bodies in the “To bodies” will be automatically calculated, and it is exposed as tolerance value. The user can modify it further.
Remove entities from existing mesh controlIf the toggle is ON, it will remove entities from existing(old) mesh control.
Example(for matching faces)
Input
Output
