ATRTOU
This function reads the UNITS block from the road property file and returns a character array which contains the unit strings.C Calling Sequence
int c_atrtou(int *id, char *units);
Arguments
Argument | Type | Description | |
id | Integer | Input | This is an Identifier which is associated with the TeimOrbit file. |
Units
Character Array | Output | This Units (block) is a array of five strings which is read from the TeimOrbit file. |
FORTRAN Calling Sequence:
DLLFUNC void STDCALL ATRTOU(int *id, char *units, int dummylen)
Arguments
Units
Note: Before using the ATRTOU function, you must use the int
c_rto_open_file(const
char *fName)
function to open the road property file for reading the UNITS block.
If the units block is not found in the property file or if the unit string is not found
inside the units block then ATRTOU function returns with an error.
