2026
View new features for Altair HyperWorks 2026.
Create, organize, and manage parts and subsystems.
The Developer ribbon contains tools for automation and customization.
Plot data can be post-processed using both HyperMesh and HyperGraph.
MotionView has many pre-processing and post-processing capabilities with regards to flexible bodies, or flexbodies, for multibody dynamics models.
Add an FMU to the model or export a model as an FMU.
The Altair Soft Soil Tire model provides a way to simulate the dynamic behavior of a tire on a surface that is compressible such as clay, dry sand, regolith, and ice-covered snow.
The Altair Soft Soil model provides a way to simulate the dynamic behavior of a track system on a surface that is compressible such as clay, dry sand, regolith, and ice-covered snow.
Using the predefined obstacle templates, a variety of obstacle types can be created which are superimposed on the existing soft-soil road geometry.
Reference material for the scripting interface which is a set of Tcl/Tk commands.
Learn about the Soft Soil Tire model, obstacle types, and road modeling.
