Obstacles
Using the predefined obstacle templates, a variety of obstacle types can be created which are superimposed on the existing soft-soil road geometry.
Implementation
In order to properly position the obstacle, the X and Y coordinate of the obstacle’s center as well as the THETA angle, which defines its orientation, must be provided, as shown in Fig. 1.
By default, each obstacle is created as deformable, making use of the global soft-soil parameters (see Fig. 2). In order to change its default state, the optional parameter MAT can be set to ‘RIGID’ or a user-defined ‘MAT_LABEL’. More specifically, in the first case, the obstacle is rigid (non-deformable) and the tire-rigid road interaction is implemented using the Fiala tire model (see Fig. 3). On the other hand, in the second case the obstacle is still deformable. However, instead of the global soft-soil parameters, a new set of parameters is used for the obstacle’s region which is defined in the new block ‘MAT_LABEL’, as depicted in Fig. 4. Finally, if the block ‘MAT_LABEL’ cannot be found in the road data (.rdf) file, the simulation proceeds using the global soft-soil parameters.
$-----------------------------------------------------SOIL_PROPERTIES
[PROPERTIES]
 PHI                  = 0.649      $ Angle of internal shearing resistance [angle]
 C                    = 800.0      $ Soil apparent cohesion [force/length**2]
 KX0                  = 0.043      $ Shear deformation module [length/angle]
 KX1                  = 0.036      $ Shear deformation module [length]
 KY0                  = 0.020      $ Shear deformation module [length/angle]
 KY1                  = 0.013      $ Shear deformation module [length]
 KC                   = 1370.0     $ Pressure-sinkage parameter [force/length**(n+1)]
 KPHI                 = 8.14E5     $ Pressure-sinkage parameter [force/length**(n+2)]
 SINKAGE_EXPONENT     = 1.0        $ Sinkage exponent n [-]
 C1                   = 0.4        $ Parameter for wheel angle of maximum normal stress [-]
 C2                   = 0.15       $ Parameter for wheel angle of maximum normal stress [-]
 SOIL_STIFFNESS       = 8.14E6     $ Soil elastic stiffness [force/length**3]
 SOIL_DAMPING         = 500.0      $ Soil damping [force*time/length]
 SOIL_DENSITY         = 1600.0     $ Soil density [mass/length**3]
$--------------------------------------------------------------RECTANGULAR_OBSTACLE
[RECT_OBSTACLE]
 X                    = 0.0        $ X coordinate of obstacle's center
 Y                    = 0.0        $ Y coordinate of obstacle's center
 Z                    = 0.0        $ Z coordinate of obstacle
 LENGTH               = 1.0        $ Length of obstacle
 WIDTH                = 0.5        $ Width of obstacle
 THETA                = 0.0        $ Theta (orientation) angle of obstacle with respect to road z-axis
 UMIN                 = 0.8        $ Parameter for tire-rigid road interaction (Fiala tire model)
 UMAX                 = 1.0        $ Parameter for tire-rigid road interaction (Fiala tire model)
 CSLIP                = 20000.0    $ Parameter for tire-rigid road interaction (Fiala tire model)
 CALPHA               = 44000.0    $ Parameter for tire-rigid road interaction (Fiala tire model)
Figure 2: Example of deformable rectangular obstacle, using the global soft-soil parameters
$-----------------------------------------------------RECTANGULAR_OBSTACLE
[RECT_OBSTACLE]
 MAT                  = 'RIGID'    $ Obstacle's material
Figure 3: Example of rigid rectangular obstacle
[RECT_OBSTACLE]
 MAT                  = 'MAT1'     $ Obstacle's material
$-----------------------------------------------------MATERIAL1
[MAT1]
 MU                   = 1.0        $ Friction coefficient
 KPHI                 = 7.14E5     $ Pressure-sinkage parameter [force/length**(n+2)]
 C1                   = 0.4        $ Parameter for wheel angle of maximum normal stresss [-]
 C2                   = 0.15       $ Parameter for wheel angle of maximum normal stresss [-]
 SOIL_STIFFNESS       = 7.14E6     $ Soil elastic stiffness [force/length**3]
Figure 4: Example of deformable rectangular obstacle, using the soft-soil parameters defined in 'MAT1' block
Obstacle types
In the current tire model, the following obstacle types can be used:
  • Rectangular obstacle
  • Circular obstacle
  • Bump obstacle
  • Ramp obstacle
  • Roof obstacle
  • Sine obstacle
  • Sine-sweep obstacle (Linear/Logarithmic)
  • Plank obstacle (Beveled edges/Round edges)
  • Custom obstacle
Rectangular Obstacle
To create a rectangular obstacle, a new block (RECT_OBSTACLE block) is necessary in the road data (.rdf) file that contains the following parameters:
Parameter Description Units
X X coordinate of obstacle’s center Length
Y Y coordinate of obstacle’s center Length
Z Z coordinate of obstacle Length
LENGTH Length of obstacle Length
WIDTH Width of obstacle Length
THETA Theta (orientation) angle of obstacle Angle
UMIN Parameter for tire-rigid road interaction (Fiala tire model) -
UMAX Parameter for tire-rigid road interaction (Fiala tire model) -
CSLIP Parameter for tire-rigid road interaction (Fiala tire model) Force
CALPHA Parameter for tire-rigid road interaction (Fiala tire model) Force
MAT Obstacle’s material. Optional parameter, default value is ‘SOFT_SOIL’ -
Circular Obstacle
To create a circular obstacle, a new block (CIRC_OBSTACLE block) is necessary in the road data (.rdf) file that contains the following parameters:
RADIUS Radius of circle obstacle Length
Bump Obstacle
To create a bump obstacle, a new block (BUMP_OBSTACLE block) is necessary in the road data (.rdf) file that contains the following parameters:
Z Z coordinate of bump's center Length
RADIUS Radius of bump Length
Ramp Obstacle
To create a ramp obstacle, a new block (RAMP_OBSTACLE block) is necessary in the road data (.rdf) file that contains the following parameters:
Z_START Z coordinate of obstacle's starting point Length
PHI Phi (inclination) angle of obstacle Angle
Roof Obstacle
To create a roof obstacle, a new block (ROOF_OBSTACLE block) is necessary in the road data (.rdf) file that contains the following parameters:
Z Z coordinate of obstacle's midpoint Length
Sine Obstacle
To create a sine obstacle, a new block (SINE_OBSTACLE block) is necessary in the road data (.rdf) file that contains the following parameters:
AMPLITUDE Amplitude of sine wave Length
WAVELENGTH Wavelength of sine wave Length
Sine-sweep Obstacle
In this obstacle type, the amplitude and the frequency of the sine wave vary as a function of the longitudinal distance s. More specifically, two cases can be distinguished for the calculation of the obstacle’s height .
Linear Sweep
Logarithmic Sweep
To create a sine-sweep obstacle, a new block (SINE_SWEEP_OBSTACLE block) is necessary in the road data (.rdf) file that contains the following parameters:
AMPLITUDE_START Amplitude of obstacle's starting point Length
WAVELENGTH_START Wavelength of obstacle's starting point Length
AMPLITUDE_END Amplitude of obstacle's end point Length
WAVELENGTH_END Wavelength of obstacle's end point Length
SWEEP_TYPE Sweep type (‘LINEAR’ or ‘LOGARITHMIC’). Optional parameter, default value is ‘LINEAR’ -
Plank Obstacle
Using a plank obstacle, two different cases can be distinguished regarding the shape of its edges. In detail, beveled edges are used when the BEVEL_EDGE_LENGTH parameter is positive. On the other hand, round edges are created with a negative value of this parameter, where the radius of the corner is equal to |BEVEL_EDGE_LENGTH|.
To create a plank obstacle, a new block (PLANK_OBSTACLE block) is necessary in the road data (.rdf) file that contains the following parameters:
BEVEL_EDGE_LENGTH Length of the beveled edge (45° angle). If this parameter is negative, the obstacle is created with round edges, where the radius is equal to |BEVEL_EDGE_LENGTH| Length
Custom Obstacle
The custom obstacle allows the creation of an arbitrary shape obstacle in the soft-soil road. The obstacle is defined as a Point Cloud Data (PCD) road added in the CUSTOM_OBSTACLE block.
The PCD are roads represented by Finite Element surfaces made of triangular mesh. The custom obstacle can be specified as a PCD by adding the nodes and elements table in the .rdf file or specifying an OptiStruct .fem file. For more information consult PCD [Point Cloud Data].
FILE_PATH Point Could Data road file (.rdf) representing the obstacle. -
OBSTACLES Block
Finally, in order to support more than one obstacle of each type (for example rectangular, circular, and so on), an extra block (OBSTACLES block) can be defined that contains a list of the obstacle names for each type, as shown in Fig. 14. It should be emphasized that this block is necessary only in cases where more than one obstacle of a specific type (for example rectangular, circular, and so on) exists in the model and only for the specific obstacle type. In all other cases, the obstacles are created using the blocks presented previously (RECT_OBSTACLE block for a rectangular obstacle, CIRC_OBSTACLE block for a circular obstacle, and so on). In addition, it should be noted that the obstacle names in each list need to be provided as comma-separated values, as depicted in the example below.
$-----------------------------------------------------OBSTACLES
[OBSTACLES]
 RECT_OBSTACLE          = 'RECT_OBS1,RECT_OBS2,RECT_OBS3'
 CIRC_OBSTACLE          = 'CIRC_OBS1,CIRC_OBS2,CIRC_OBS3'
 BUMP_OBSTACLE          = 'BUMP_OBS1,BUMP_OBS2,BUMP_OBS3'
 ROOF_OBSTACLE          = 'ROOF_OBS1,ROOF_OBS2,ROOF_OBS3'
 RAMP_OBSTACLE          = 'RAMP_OBS1,RAMP_OBS2,RAMP_OBS3'
 SINE_OBSTACLE          = 'SINE_OBS1,SINE_OBS2,SINE_OBS3'
 SINE_SWEEP_OBSTACLE    = 'SINE_SWEEP_OBS1,SINE_SWEEP_OBS2,SINE_SWEEP_OBS3'
 PLANK_OBSTACLE         = 'PLANK_OBS1,PLANK_OBS2,PLANK_OBS3'
[RECT_OBS1]
 X                      = 0.0
 Y                      = 0.0
 Z                      = 0.0
 LENGTH                 = 1.0
 WIDTH                  = 0.5
 THETA                  = 0.0
 UMIN                   = 0.8
 UMAX                   = 1.0
 CSLIP                  = 20000.0
 CALPHA                 = 44000.0
Figure 14: New block (OBSTACLES block) in order to support more than one obstacle of each type
Property File Examples
[RECT_OBSTACLE]
Figure 15: Example of deformable rectangular obstacle in road data (.rdf) file
Circular Obstacle
$-----------------------------------------------------CIRCULAR_OBSTACLE
[CIRC_OBSTACLE]
 RADIUS         = 0.3        $ Radius of circular obstacle
Figure 16: Example of deformable circular obstacle in road data (.rdf) file
Bump Obstacle
$-----------------------------------------------------BUMP_OBSTACLE
[BUMP_OBSTACLE]
 Z              = 0.0        $ Z coordinate of bump's center
 WIDTH          = 0.3        $ Width of obstacle
 RADIUS         = 0.1        $ Radius of bump
Figure 17: Example of deformable bump obstacle in road data (.rdf) file
Ramp Obstacle
$-----------------------------------------------------RAMP_OBSTACLE
[RAMP_OBSTACLE]
 Z_START        = 0.0        $ Z coordinate of obstacle's starting point
 PHI            = 0.087      $ Phi (inclination) angle of obstacle
Figure 18: Example of deformable ramp obstacle in road data (.rdf) file
Roof Obstacle
$-----------------------------------------------------ROOF_OBSTACLE
[ROOF_OBSTACLE]
 Z              = 0.05       $ Z coordinate of obstacle's midpoint
Figure 19: Example of deformable roof obstacle in road data (.rdf) file
Sine Obstacle
$-----------------------------------------------------SINE_OBSTACLE
[SINE_OBSTACLE]
 AMPLITUDE      = 0.05       $ Amplitude of sine wave
 WAVELENGTH     = 1.0        $ Wavelength of sine wave
Figure 20: Example of deformable sine obstacle in road data (.rdf) file
Sine-sweep Obstacle
$-----------------------------------------------------SINE_SWEEP__OBSTACLE
[SINE_SWEEP_OBSTACLE]
 LENGTH            = 6.0             $ Length of obstacle
 AMPLITUDE_START   = 0.05            $ Amplitude of obstacle's starting point
 WAVELENGTH_START  = 1.0             $ Wavelength of obstacle's starting point
 AMPLITUDE_END     = 0.01            $ Amplitude of obstacle's endpoint
 WAVELENGTH_END    = 0.5             $ Wavelength of obstacle's endpoint
 SWEEP_TYPE        = 'LOGARITHMIC'   $ Sweep type ('LINEAR' or 'LOGARITHMIC'). Default value is 'LINEAR'
Figure 21: Example of deformable sine-sweep obstacle in road data (.rdf) file
Plank Obstacle
$-----------------------------------------------------PLANK_OBSTACLE
[PLANK_OBSTACLE]
 BEVEL_EDGE_LENGTH   = 0.02        $ Length of the beveled edge
Figure 22: Example of deformable plank obstacle in road data (.rdf) file
Custom Obstacle
$----------------------------------------------------------------CUSTOM_OBSTACLE
[CUSTOM_OBS]
 X                   = -5.0                        $ X coordinate of obstacle's center
 FILE_PATH           = 'PCD_road_obstacle.rdf'     $ Point Could Data road file representing the obstacle
Figure 23: Example of deformable custom obstacle in road data (.rdf) file
