Units Block
The units block specifies the unit system used for the values in the property file. This is a mandatory block. The units must be defined for length, time, force, mass, and angle.
The table below describes the valid choices for the Units block:
Parameter | Type | Description |
LENGTH | quoted_string | Valid length units are:
ANGLE | quoted_string | Valid length units are:
FORCE | quoted_string | Valid length units are:
MASS | quoted_string | Valid length units are:
TIME | quoted_string | Valid length units are:
The following is an example of a Units
block:
$--------------------------------------- UNITS
[UNITS]
LENGTH = 'mm'
ANGLE = 'degree'
FORCE = 'newton'
MASS = 'kg'
TIME = 'second'
