Property File to SI Conversion Factors
This function converts the units from the property file to SI units.C Calling Sequence
int c_rto_file2si_conversion_factors(double *cFactors);
Arguments
| Argument | Type | Description | |
| cFactors | Double Precision | Input | Converts all the units from TeimOrbit file to SI units. |
FORTRAN Calling Sequence:
DLLFUNC void STDCALL RTO_FILE2SI_CONVERSION_FACTORS_F2C(double *cFactors, int
*Success)
Arguments
| success | Integer | Output | If the value is read then success return 1 or else 0. |
