User Written Tire and Road Models
User Written Tire models are implemented as user subroutines that compute the tire forces and moments, and the user road model is implemented as a subroutine that computes the road height at a given point.
Both the user defined tire and user defined road follow the established TYDEX standard.
User defined tire models can run along with road models provided with MotionSolve or it can run with a user defined road model.
Reasons for Writing Tire and Road Models
Tires and its interface with the road can be modeled in multiple ways and a lot of literature and models exist. The Tire Data Exchange (TYDEX) is an accepted standard developed and unified by an international working group. The user written tire models allow any tire model that conforms to this format to be used with multibody dynamics simulation using MotionSolve.
User defined road models also conform with the above mentioned TYDEX standard which allows the user to simulate any road model that conforms to the standard.
Many commercially and openly available tire and road models are described in the TYDEX format and can be used with MotionSolve using this user written tire interface.
Skills Required
Users are expected to have an intermediate proficiency of using MotionView and MotionSolve.
  • Understanding of user defined entities of MotionSolve
  • Basic programming language (FORTRAN/C/C++)
  • Domain knowledge pertaining to tire mechanics, modeling, and interaction with the road
  • Understanding of usage exposed functions (API) from MotionSolve
  • Ability to compile and link to a MotionSolve subroutine
  • Access to a debugging environment would also be helpful
Software Required
  • MotionSolve
The following topics explain the procedure to create a user defined model for use with MotionSolve.
