Multi-Threading and Tire Models
Since computing tire forces and moments during a vehicle simulation is one of the most costly tasks, multi-threaded execution of tire models on a multi-core computer can substantially reduce the clock time for a simulation.
The CDTire and FTire models offer
        multi-threaded execution with MotionSolve, while the MF-TYRE and MF-SWIFT models do not. The
        means to enable multi-threading for CDTire and FTire do differ, therefore each method is
        described in the table below:
| Tire Model | Multi-Threaded | Enabling Multi-Threading |
| CDTire | YES | The CDTire.ini file controls multi-threading for CDTire.
                  To enable multi-threading, set the maximum threads in the parallel block to a
                  number greater than one.  For example: [Parallel] MaxThreads=4  |
| FTire | YES | Multi-threading is controlled by the environment variable NUSOL_MT_TIRE.
| MF-TYRE and MF-SWIFT |
                NO | Not Applicable |
