Introduction of AC Supplied Conductors
Introduction
For electrical engineering and power electronics devices, this AC Supplied Conductors “SCAC” solution electrical analysis of 3D complex interconnections thanks to its intrinsic ability to include the impact of non-ideal behaviors (parasitic couplings) of these structures. This solution makes it possible to calculate the electrical current distribution within the structure and its connected active and passive components, as well as the distribution of the Joule losses, which can be evaluated and then displayed as color shades.
The AC Supplied Conductors solution provides the user the ability to compute, for a given set of 3D conductor, dielectric and linear soft magnetic volumes, the frequency-dependent electrical current repartition, and the Joule losses via the definition of a circuit connected to these volumes. The physical pins where electric and electronic components are connected are defined using N-pins Conductor components. The other components available for this solution are resistors, inductors, capacitors, and alternative current / voltage sources.
Moreover, the capability to plot voltage/current in a component as a function of the frequency is available to enable the user to analyze the impact of the so-called resistive, inductive, and capacitive effects to the whole parasitic behavior of the simulated interconnects.
The Joule losses in conductors can also be plotted as function of the frequency: these values can be used to calculate the heat dissipation using Electronics Thermal solution in SimLab (via ElectroFlo solver). This can be done by defining Heat Source LBC for each body using its according Joule losses value.
SCAC Workflow
- Geometry definition by Import CAD/ECAD
- Model Discretization
- Material and Circuit Designer definitions
- Solution Settings (Solver Settings and Result Request and Format and Execute Options)
- Solve
- Results
All functions are available in the different ribbon bars Geometry, Mesh, Analysis, ...
The content of each ribbon is adapted depending on the active solution.
Main Limitations of the SCAC Solution
- Conductive, dielectric and linear soft magnetic materials are accepted. The non-linear soft magnetic and the permanent magnets are not supported.
- Mesh limitations:
- Pyramid mesh type is not supported for this version.
- 2nd order mesh is currently not allowed.
