Valve Controller BC
This BC is typically applied at the interface between the hot runner and the cold runner/part.
- open
- closed
Its state also depends on whether it is filling/packing/cooling phase.
The state of a valve can be changed using a variety of controls and they are applied in sequence.
Controller type
Flow Front Location:
Select a node and specify the valve state. When the flow front reaches that node, it will open/close the valve. This is an often-used condition.
- Time Controller:
Specify the time to open/close the value surface. This is also an often-used condition.
Value Controller:
The value considered is always pressure in this release. User can select a node, specify pressure value and condition Based on that the valve is open or close
Percentage Filled Volume:
Specify the 3D part and the percentage of filling. Once that part/assembly is filled to the specified percentage, it will open or close the valve.
