How to Load Results?
Results must be available before attempting post-processing.
Load Results
- Go to Solution browser
- Make sure results are available and Result section is shown in Green color
- If results section is not shown in Green color then right click on current solution
and select Attach Results and drill down to correct result file (*.h3d
file).
- Right click on Results and select Display
