Modify Link State
The link state defines if the weld created during connector realization connects to geometry or mesh on the link.
This is applicable to only components and surfaces entities that can contain geometry and/or mesh information.
Update Link by Directly Editing Column Data in the Connector Browser
In the Connector Entity Browser, select the link(s) or connector(s) to update,
then click the Structure column and select a new link
state.
