Auto Area
Use the Auto Area tool to identify locations to create area connectors between components and parts. This process works on mesh.
  1. From the Connectors ribbon, Area tool group, click the Auto Area tool.
  2. Select the parts to automatically add connectors to.
  3. Click on the guide bar and define the following options.
    Tolerance Type
    The type of distance to be used.
    Proximity Tolerance
    The distance between the parts.
    Shell Thickness
    The thickness of the parts is used.
    Add on
    Adds an extra portion to the shell thickness.
    Multiplier
    Multiplies the shell thickness by the specified amount.
    Search tolerance
  4. Click on the guide bar.
    The created output is connectors between the selected hole type taking into account the associated parameters. The connectors are in the unrealized state.
