Auto Fastener
Use the Auto Fastener tool to identify and pair holes to create fastener connectors between components and parts. The process works on 2D/3D mesh.
  1. From the Connectors ribbon, Fastener tool group, click the Auto Fastener tool.
  2. Select the parts to automatically add connectors to.
  3. Click on the guide bar and define the following options.
    Hole Type
    The Hole types that will be looked for the in the model.
    Max hole dia
    The maximum allowable hole diameter.
    Min hole dia
    The minimum allowable hole diameter.
    Tolerance
    The distance between the holes.
    Max angle
    The angle between the normal to the holes.
    Allow holes to tubes
    Allow the connection between holes and tubes.
    Allow self
    If there are multiple holes on the same link that could be a part of the same stack.
    Center Connector
    Create the connector between the holes.
    Only Two Layers
    Limit the created connectors to a maximum of two layers.
  4. Click on the guide bar.
    The created output is connectors between the selected hole type taking into account the associated parameters. The connectors are in the unrealized state.
