Convert Style
Convert connectors of one specific style into a different style, for example a spot connector into a bolt connector using the Convert option.
Highlight the connector(s) you want to convert, then right-click and select context menu.
(spot, bolt, seamline) from the
The converted connector(s) will be unrealized and placed in the
Undefined folder. Once you convert a connector, you will not be able to revert
it back to its original state. The only information that will be retained
includes: number of layers, tolerance, and link information.
Convert Settings
Settings used to define how connectors are converted.
Access Convert Settings by right-clicking on a connector and
selecting from the context menu.
Option | Description |
Maintain as Line | To keep line connectors as line connectors after the
conversion, select the Maintain as Line
checkbox. When this checkbox is off, line connectors will be
converted to single point connectors per each connector
point. Note: Only applicable when spot or boltlines are being
converted to seamlines. |
