The link rule defines how a connector treats an entity added as a link.
Adding a link with the ID or name rule forces the connector to retain the link’s ID
or name even if that link entity no longer exists in the database. Adding a link
with the at fe-realize rule ensures that each time a connector is realized the
closest entity of the correct type is found and connected.
Update Link by Directly Editing Column Data in the Connector Browser
In the Connector Browser, select the link(s) or
connector(s) to update, then click the Rule column and
select a new link rule.
In the Link Entity Browser, updates can be performed on a single or multiple
selected links. When you update a link in the Link Entity Browser, link
references will be automatically updated in the Connector Entity Browser. In the
Connector Entity Browser, updates can be performed for an individual link on a
single or multiple selected connectors in the Connector Entity Browser.
