Spring (Rigid)
This realization creates spring (CBUSH, CELAS1, CON3D2) elements between the shell and/or solid elements and then connects using Rigid elements (RBE2, RBE3, DCOUP) elements.
Realization Details
- Create Vector
- Create orthogonal vectors for each CBUSH element created during the sealing realization. These vectors are used to define the orientations of the CBUSH elements, which is important to the stiffness defined in the related PBUSH cards.
- Head Element Type
- Use to choose the Head Element type (only available for OptiStruct and Nastran).
- Body Element Type
- Use to choose the Body Element type (only available for OptiStruct and Nastran).
- Rbe3 Radius
- Documentation for Rbe3 Radius can be found here.
Legacy Realizations
The following realizations are replaced by Spring (Rigid):
- Sealing
- Bush
- Reb3-cbuish-rbe3
- Rbe3-celas-rbe3
- Cbush (rigid)
