Fastener (Nodes)
Restriction: Only available in Abaqus.
Creates a Node Set that contains the nodes that are selected to create the connector element, and creates an empty Element Set. Connector elements are not created for this realization type. Abaqus creates the required connector elements on its own.
This realization uses the prop_fastener_nodes.tcl property
script.
