Beam (Contact)
This realization creates beam elements between the shells and/or solid elements, connecting them using a contact definition.
Contact
- Creation
- Specifies how many contacts will be created depending on the number of links.
- Single Contact
- Specifies if the property created will be automatic or the sets will be user specified.
- Local
- The contact will be created in a localized area around the connector
rather than the entire link.
Figure 2. Local contact creation
- Create HAZ
- Creates a Heat Affect Zone around the connector. This option is enabled only when the Local option is ON. The same elements that are used to create the localized contact are used for HAZ creation. Properties and materials for the zone are defined from the connector control.
- Card Image
- Specifies the card image to be used in the contact definition(s).
Property and Material
- Material Card Image
- Defines the card image of the material(s) created.
Legacy Realizations
The following realizations are replaced by Beam (Contact):
- mat100
- mat196
- HC beam spotweld
- HC glue
- HC glue structural adhesives
- HC welding line
- HC hemming
