plotyy
Plots given datasets in independent y-axes and a common x-axis.
plotyy(x1, y1, x2, y2)
ax = plotyy(x1, y1, x2, y2)
[ax h1 h2] = plotyy(x1, y1, x2, y2)
x1, y1
Dataset to be plotted in the first y-axis.
Type: double | integer
Dimension: scalar | vector | matrix
x2, y2
Dataset to be plotted in the second y-axis.
Outputs
ax
A vector containing the handles of the two y-axes.
Type: double
Dimension: vector
h1
Handle of the first line graphics object.
h2
Handle of the second line graphics object.
Examples
Simple example:
clf;
x = [0:0.1:2*pi];
plotyy(x, sin(x), x, 2*cos(x));
Set secondary axis properties:
clf;
x = [0:0.1:2*pi];
[ax h1 h2] = plotyy(x, sin(x), x, 2*cos(x));
set(ax(1),'fontsize',12);
ylabel(ax(2), 'Y2 axis label');
ylim(ax(2), [-4 4]);
set(ax(2),'ycolor',[0 120 0]);
set(ax(2),'ytick',5);
Add a curve in an existing secondary axis:
clf;
x = [0:0.1:2*pi];
hold
plot(ax(2), x, 4*cos(x));
Figure 3.
