- Invoke Compose
Run the software using console, GUI, batch and start-up file methods.
- Languages and IDE
Learn about the supported languages and utilities for coding in Compose.
- Edit Scripts
Learn how to open, create, and close scripts.
- Run Scripts
Click Run to execute a script.
- Code Analysis
Run static code analysis.
- Profile Scripts
Run files and profile them at the same time.
- Views Browser
The Views browser contains two tabs to display the plots and variable editors.
- Create Plots
In Compose, you can create 2-D and 3-D plots using OML plotting commands.
- Edit Properties of Plots
In Compose, you can edit the properties of plots created with OML plotting commands.
- Debug Code
Use the Debugger to find errors in the script.
- Compose Notebook
The
Compose Notebook is a web-based implementation of
Compose’s
OpenMatrix Language (
OML) into a Jupyter Notebook. Notebooks (see
www.jupyter.org) are a powerful way to execute and demonstrate scripted languages.
- Graphical User Interfaces
Learn about the methods, functions and file input and output options for creating a GUI.
- CAE Applications
- HDF5 Viewer
Use the HDF5 Viewer to import data and navigate through the hierarchy of .hdf5 files.
- MAT Explorer
Use the MAT Explorer interface to explore and load variables from one or more .MAT files, providing a visual way to see the contents of selected .MAT files and to import variables into an OML session.
- Signal Viewer
Use the Signal Viewer to import and treat (basic) signals in both time and frequency domains, as well as generate signals based on the most common waveforms such as step, chirp and sawtooth.
- Plot Assistant
Use the Plot Assistant to create plots from the various 2D and 3D OML plot types.
- Extension Manager
Use the Extension Manager to create custom extensions, load extensions automatically, and add custom documentation for defined features.
- Use OML Functions in HyperWorks Products
OML functions can be registered from the Compose graphical user interface or via a preference file and later opened in certain HyperWorks products.
- OML Libraries
Additional libraries can be written in the C/C++ or Fortran language and interfaced with OML.
