2026
Learn about the features and functionality available in Compose.
Learn about the supported languages and utilities for coding in Compose.
Learn about the new features and enhancements in Compose.
Discover Compose, including its language support and system requirements.
The Compose tutorials and associated example model files help introduce you to the basic functionality of the software.
Run the software using console, GUI, batch and start-up file methods.
Open Matrix Language is the primary math and scripting language for Compose.
Compose supports the Tcl scripting language, revision 8.5.9, for editing, execution, and debugging.
Compose supports Python 3.10 as a scripting language.
Compose supports R as a scripting language for both edition and execution.
The User Profile tool facilitates a choice of languages for the Compose coding environment.
The Compose Integrated Development Environment offers many tools which can be used for authoring and debugging operations.
Learn how to open, create, and close scripts.
Click Run to execute a script.
Run static code analysis.
Run files and profile them at the same time.
The Views browser contains two tabs to display the plots and variable editors.
In Compose, you can create 2-D and 3-D plots using OML plotting commands.
In Compose, you can edit the properties of plots created with OML plotting commands.
Use the Debugger to find errors in the script.
The Compose Notebook is a web-based implementation of Compose’s OpenMatrix Language (OML) into a Jupyter Notebook. Notebooks (see www.jupyter.org) are a powerful way to execute and demonstrate scripted languages.
Learn about the methods, functions and file input and output options for creating a GUI.
Use the HDF5 Viewer to import data and navigate through the hierarchy of .hdf5 files.
Use the MAT Explorer interface to explore and load variables from one or more .MAT files, providing a visual way to see the contents of selected .MAT files and to import variables into an OML session.
Use the Signal Viewer to import and treat (basic) signals in both time and frequency domains, as well as generate signals based on the most common waveforms such as step, chirp and sawtooth.
Use the Plot Assistant to create plots from the various 2D and 3D OML plot types.
Use the Extension Manager to create custom extensions, load extensions automatically, and add custom documentation for defined features.
OML functions can be registered from the Compose graphical user interface or via a preference file and later opened in certain HyperWorks products.
Additional libraries can be written in the C/C++ or Fortran language and interfaced with OML.
Reference guides are available for functions and commands supported by OML, Tcl, and Python.
Get help for the optional libraries that are available in the Extension Manager.
You've got questions? We've got answers!
