User Start-Up File
Invoke Compose with a user-defined start-up file.
Compose reads and executes the user-defined start-up OML script when launched.
The script can be found in: <user directory>\.altair\Compose<version>\hwx\Compose_startup.oml.
This path is also returned by the command startupscript_path.
The file can be edited directly or in the Compose
Editor by running the startupscript_edit
command.
You can restart Compose to see the result. In the above example, each
time Compose is launched, the message is displayed in the Command Window.
