Run Compose in Console Mode
Opening Compose in Console mode provides a shell where Compose OML language commands can be entered at the prompt.
Complete the step depending on your situation.
![](../../images/math_solutions/compose/compose_console_mode.png)
For this setup | Do the following |
Windows PC | Invoke the Compose Console via All Programs > Altair 2024 > Compose 2024 Console. |
DOS Prompt on a PC | Run the following command: <install dir>\Compose_Console.bat or this command: <install dir>\hwx\bin\win64\ExecWinEnvComp.exe -cfg -kc -ef Comp.env -aa 0 -ex ExecMainComp.exe –toolbox -continue |
Linux Shell | <install dir>/scripts/Compose_Console |
You can run the Console application without arguments to open it.
In this mode, all OML Language features are exposed. However, every command related to the graphic windows (plotting, GUI, readvectorbuilder, and so on) is ignored.
You can use the -withgui
argument to enable the plotting and
GUI commands.
![](../../images/math_solutions/compose/figure_invoke_console_withgui.png)
