Console Execution
- On a PC, open a DOS Command Prompt window and run the following command: <install directory>\Compose_Console.bat –f <inputfile>.oml
- From a Linux shell, run the following command: <install directory>/scripts/Compose_Console –f <inputfile>.oml
This runs the OML script <inputfile> in Console mode. This is executed in batch mode unless the OML script <inputfile> contains print statements, such as printf, disp, and assignment, then this is silent and OML quits after the script is executed.
