Review Loads and Connections
Introduction
The tool is used to list the following details defined on the bodies.
- Material and Property
- Loads
- Sets
- Connections
- Contact
- Equivalenced nodes
- Shared surfaces
- 1D bolts
- The tool can be used on selected bodies in the GUI or it can be used to review
the details on the solution using Solution Name | right click option | Review |
Loads and Constraints.
- This tool provides a body-based list of the details defined on the body.
- This tool helps to find the unconnected bodies, by listing the unconnected bodies separately.
