Fan
Introduction
Fan Component is a Smart Object used define fan behavior in electronic systems.
- Fans are used to enhance convection heat transfer inside an electronic system by providing airflow to regions with high heat generation.
- In Electronics Thermal Management solution fans are considered Smart Objects.
- Fans should have a corresponding geometrical part in the 3D model
- Following fan types can be defined,
- Circular fan
- Rectangular fan
- Irregular fan fan
- The user selects the 3D body that define the fan.
- Fan flow may be applied as mass flow rate, volumetric flow rate or flow speed. Fan curve definition is under development and will be available in the next release.
- User can set the P-Q curve to define the fan flow.
- The startup period iteration provides gradual fan speed for best flow stability
- The heat dissipation in fan hub can be included in the analysis
- Fan swirl may be included in circular fans. Checking ON this option results in modified form to enter swirl data
- The velocity across the fan cross section will be uniform, if user enables the "Uniform fan velocity" option
Fan Failure option can be selected to perform “Loss of Cooling” analysis. Once this option selected the form will simplify and the fan behaves like a Vent object.
- Thermostat can be connected to the Fan to control the fan flow.
- Fan starts when the temperature read by the thermostat is higher than the ON Temperature.
- Fan remains ON until the thermostat temperature is lower than the OFF Temperature.
Graph plotting
Volumetric flow rate and pressure rise of the fan can be plotted by right-click on “Fan” under “Smart Objects” in solution browser. Temperature option does not apply for fans, and it will be hidden in next release.
