Voltage
Introduction
Voltage boundary condition is used to assign constant electrical voltage to one or more faces or bodies.
Electrical effects must be activated when using Voltage BC’s. It can be activated by Solution > Electronics Thermal Management > Include electrical effects
- The user can select the application region by clicking on desired faces or bodies, with appropriate mouse selection control.
- The total Voltage (in volts) will be applied evenly to all selected faces or bodies.
- The voltage can be either constant or variable if a multiplier function is defined
when creating the boundary condition.
- There are three types of multiplier tables:
- Time - Multiplier value varies as a function of time.
- Iteration - Multiplier value varies as a function of the iteration.
- Sensor – Multiplier value varies based on the selected sensor output.
- Thermostat - Multiplier value varies based on the ON/OFF status of the selected thermostat.
