Solar Radiation
Introduction
Solar radiation BC is used to simulate the radiation heat transfer interaction between Sun and the selected surfaces.
- The solar ray direction represents the position of sun with respect to the selected solid surfaces.
- Emissivity is a property that defines how efficiently a surface emits thermal radiation compared to a perfect blackbody.
