Heated Surface
Introduction
Heated Surface BC is used to assign constant heat to one or more faces.
- The user can select the application region by clicking on desired faces, with appropriate mouse selection control.
- The total heat (in watts) will be applied distributed to all selected faces proportional to each surface area.
