Temperature
Introduction
This boundary condition is used to assign fixed temperature on a list of surfaces or parts.
- For a given BC all entities must be of the same type (all bodies or all faces).
- The user can select one or more bodies or faces to apply a fix temperature to, with appropriate mouse selection control.
- Temperature can be either constant or variable if a multiplier function is defined when creating the boundary condition.
- If a multiplier function is defined it will also convert based on the unit system
and temperature value.
- There are three types of multiplier tables:
- Time - Multiplier value varies as a function of time.
- Iteration - Multiplier value varies as a function of the iteration.
- Sensor – Multiplier value varies based on the selected sensor output.
- Thermostat - Multiplier value varies based on the ON/OFF status of the selected thermostat.
