System Requirements: Inspire Implicit Modeling
The minimum system requirements to run Inspire Implicit Modeling.
Operating System
  • Windows 10 (64-bit)
  • Windows 11 (64-bit)
  • Linux Enterprise Server 15 SP3 Red Hat Enterprise
  • Linux 8.4/Oracle Linux 8.4 or newer
  • CPU AVX2 support
Memory
  • 16 GB of RAM (higher recommended)
Graphics Hardware
Inspire Implicit Modeling prefers a GPU-based system but will run on a CPU-only computer. That said, it is much slower. To get the true benefits, a GPU is strongly recommended.
It is best to use NVIDIA RTX graphics with at least 16 GB of RAM. Other vendors (AMD, Intel) GPU graphics may work but have not yet been qualified. Smaller amounts of RAM (4 GB or 8 GB) will work depending on model size and complexity.
  • NVIDA GPU
    • Supported generations include: Pascal, Volta, Turing, Ampere, Ada, Hopper, or newer
  • NVIDA Graphics Driver
    • Version 460.89 or newer
