Transform: Two Arcs
This is used to transform a body(movable) by picking two arcs on movable body and two arcs on fixed body such that the arcs on both bodies will match each other. Supports both Mesh and CAD bodies.
Flip Movable BodySometimes, while doing transformation, the movable body may get flipped. Users, can use this toggle to flip it back. This toggle will be enabled only after performing the operation.
CopySelect this toggle to take a copy of movable body. A new body will be created.
With LBCSelect this toggle to copy the LBC of movable body to new bodies.
Example - Mesh
Example - CAD
