Transform: Mirror
This is used to mirror the body by given plane.
CopySelect this toggle to take a copy of input body. A new body will be created.
This option is supported only for FE models and Parasolid models imported with "Save geometry in database" option.
- With LBC
Select this toggle to copy the LBC of input body to new bodies.
Note: For CAD input, the associated mesh controls also will be
transferred.
- Merge the input and mirrored bodies
After mirroring, the input and the new bodies get joined and merged into a single body. It supports only mesh bodies.
