Transform: Offset
This is used to offset the face in the normal direction by given distance. The offset face will be created as a new body.
Create side faceSelect this toggle to create side face between the input face and its adjacent faces.
Note: Offset CAD face is supported only for Parasolid models imported with "Save
geometry in database" option enabled.
Example(Create
side face = ON)
CAD Example(Create side face = OFF)
CAD
Example(Create side face = ON)
