Transform: Rotate
This is used to rotate a body about an axis by given angle.
CopySelect this toggle to take a copy of input body. A new body will be created.
This option is supported only for FE models and Parasolid models imported with "Save geometry in database" option.
With LBCSelect this toggle to copy the LBC of input body to new bodies.
MergeSelect this toggle to merge all the new bodies. Tolerance value should be provided for merging.
Note: For CAD input,the associated mesh controls also will be transferred.
