Transform: Translate
This is used to translate the bodies/faces in a direction for given distance.
CopySelect this toggle to take a copy of input body. A new body will be created.
This option is supported only for FE models and Parasolid models imported with "Save geometry in database" option.
With LBCSelect this toggle to copy the LBC of input body to new bodies.
Note: For CAD input,the associated mesh controls also will be transferred.
