getresultsMinMaxValue
Overview
This utility is used to get the Maximum and minimum value for the current displayed results component.
simlab.getresultsMinMaxValue()
Use Case
- This utility can be used to get the Minimum and Maximum results value for the displayed results component. User can visualize contour for visible entities like faces/bodies/sets etc… and then can get the Max and min value.
Utility Input/output
Sample
Note: Sample Script
