Measure
Overview
This utility supports scripting for the distance measurement tool.
DistanceBetweenTwoEntities=''' <DistanceBetweenTwoEntities UUID="53537c0a-6606-4b36-9a95-c05be32f39fc">
<SupportEntity1>
<Entities>
<Model>”ModelName”</Model>
<Face></Face>
</Entities>
</SupportEntity1>
<SupportEntity2>
<Entities>
<Face></Face>
</Entities>
</SupportEntity2>
</DistanceBetweenTwoEntities>''';
Distance, Del_x, Del_y ,Del_z = simlab.measure(DistanceBetweenTwoEntities);
Utility Input/output
Example DOM Node Format
Below example does calculate the distance between two faces. Users can calculate the distance between different entities by providing the appropriate support entities in the DOM node.
Note: Sample Script
