Solution Browser - Change default Run location
Introduction
The following steps explain how to change solution browser default folder location for SimLab 2019.2.
Step-by-step guide
- Solutions Right click > Set Working Directory: used to select run
location
- User can open , modify and reset this location using right click options.
