Create Link Attachments to Connectors
Create new connectors from attachments or from existing collectors.
From the Connectors ribbon, click the Connect
Attachments tool.
Figure 1. -
Click
on the guide bar.
Choose an option in the Selection tab.
- From Attachments - After you create and define attachments, you can create connectors using a tolerance search.
- From Existing Connectors - Convert existing connectors into attachment links.
Choose a detection method in the Link Detection tab.
Connectors and attachments can be selected automatically or manually.
For attachments, you must enter a tolerance and angle value. The tolerance search will look normal to the hole (within 100) of the created attachment to find other attachments.
- If link detection is set to Manual, use the selector on the guide bar to choose attachments or connectors.
If creating connectors from attachments, use the drop-down menu to assign an
attachment control to the connector.
Choose a previously defined control or click Create New to open the Control Manager and define a new control. If you select Undefined, the connector will be created without a control.
By default, an assigned control is realized.
On the guide bar, complete one of the following:
- Click
to apply and stay in the tool.
- Click
to apply and close the tool.
- Click
to exit the tool without applying.
- Click
