Auto Attachments
Use the Auto Attachments tool to identify holes on parts and create attachments.
This process works on 2D/3D mesh.
Important: The Auto Attachments tool
only works with parts. If no parts are present in session, then the tool will
not execute.
From the Connectors ribbon, Attachments tool group, click the Auto
Attachments tool.
- Select parts to automatically add attachments to.
From the guide bar, click
and define the following options.
- Search tolerance
- The tolerance to be assigned to the created attachments.
- Min Dimension
- The minimum hole diameter to consider.
- Max Dimension
- The maximum hole diameter to consider.
On the guide bar, complete one of the following:
- Click
to apply and stay in the tool. - Click
to apply and close the tool. - Click
to exit the tool without applying.
- Click
