Auto Connect
Use the Auto Connect tool to identify pair attachments to create connectors between or to create attachments from already existing connectors.
The connectors created using the Auto Connect tool will be Fasteners and can be viewed from the fastener tab in the Connector Browser.
  1. From the Connectors ribbon, Attachments tool group, click the Auto Connect tool.
  2. Automatically identify existing attachments in the model.
    1. From the guide bar, select Attachments.
    2. Select or create a fastener connector control to define the connection between the attachments.
    3. Click and define the following options.
      Max Angle
      The maximum angle between attachments.
      Only Two Layers
      Create connectors between two attachments only.
    4. Click .
    Connectors are created between the identified attachments. The connector type is defined from the control used in the guide bar.
  3. Automatically identify already existing connectors in the model.
    1. From the guide bar, select Connectors.
    2. Select or clear the Realize checkbox to automatically realize the connectors after they are created.
    3. Click .
    Attachments are created for each layer of the already existing fastener heads. The attachment type is defined by the fastener head configuration.
    Note: If the fastener’s head element configuration is not supported in attachments controls, the Auto Connect tool will not be able to create attachments.
