Throttle-off Turn-in
A Throttle-off Turn-in event simulates a vehicle driving straight at constant speed, turning on to a constant radius, then after reaching steady state the throttle is closed and the steering is ramped to tighten the turn.
The event includes a short straight section to allow the vehicle to come to steady state, the constant radius circle, and throttle removal. It is designed to simulate a highway exit ramp maneuver. Appropriate vehicle and tire output requests are included.
The Throttle-off Turn-in event is supported by the Cars & Small Trucks, Heavy Trucks, and Two-Wheeler vehicle libraries. Automated output reports are available to plot the results.
| Parameter Name | Description |
| Units | Describes the Length, Velocity, and Acceleration units.
| Radius | The radius of the circle that the vehicle CG follows during the constant radius portion of the event. |
| Initial straight | The distance the vehicle is driven straight and corners in a given radius to attain the steady state. |
| Velocity | The velocity of the vehicle during the event. |
| Initial lateral acceleration | Estimated initial lateral acceleration, calculated using the velocity and the turn radius. |
| Turn direction | Direction the vehicle turns during the event (as seen by the driver). |
| Throttle step duration | Time duration the throttle controller takes to completely remove the drive torque. |
| Steer ramp rate* | Rate at which steering is ramped up after the drive torque goes to zero. |
| Lean ramp rate** | Rate at which lean angle is ramped up after the drive torque goes to zero. |
| Transient time | Time duration for which the vehicle makes the drive torque zero and ramps up the steering. |
*Applicable only for Cars/Trucks (that is, Non-leaning events).
**Applicable only for Two-wheeler (that is, Leaning events).
- Initial Static and Steering Ratio
Run initial static Enables the execution of the initial static simulation. Compute steering ratio Enables the automatic calculation of the steering ratio at the beginning of the event simulation. Turn this option off to use a different Steering ratio (default value of 16 is provided). - End Time Calculation
- The parameters defined above are also used to determine the total simulation time.
The simulation time is specified in the Altair Drive File (.adf),
as shown below:
Figure 2. Maneuvers List Block for a Throttle-off Turn-in Event
In a Throttle-off Turn-in event:- MANEUVER_1 represents the initial straight-line section.
- MANEUVER_2 corresponds to the constant-radius part of the event.
The maximum simulation time for each maneuver is calculated using the following equations:Maneuver Simulation Time Equation Maneuver 1 (Initial straight+2*Radius*Entry Angle)/ Initial Velocity+5Maneuver 2 Transient timeThe actual simulation time is defined by the end conditions specified in each maneuver:Figure 3. Maneuver Blocks for a Throttle-off Turn-in Event
- MANEUVER_1 terminates when
is true for 0.1 seconds continuously. - MANEUVER_2 does not include end conditions, so it terminates at its maximum simulation time.
For more information see the Altair Driver File Blocks topic.
The total simulation time corresponds to the sum of the total simulation times for Maneuver 1 and Maneuver 2.
Controller Settings
- Non-leaning events (Cars/Trucks)
- LONGITUDINAL – TRACTION CONTROLLER SETTINGS
- Use additional control: Enables the additional feedback control for the traction
control. The gains for the controller can be edited by toggling this check
box.
Kp Proportional gain for the feedback PID controller Ki Integral gain for the feedback PID controller Kd Derivative gain for the feedback PID controller
box.
- Leaning events (Two-wheelers)
box.
box.
Signal Settings
Use the signal settings to set minimum, maximum, smooth frequency and initial values for Steering, Throttle, Brake, Gear, and Clutch signals output by the driver.
The smoothing frequency is used to control how fast the Driver changes signals. Only closed loop control signals from the Driver are smoothed. Open loop signals are not smoothed.
Road Settings
- Flat Event
- Uses a flat smooth road for the event with no required road file.When the Flat Event is selected, the Graphics Setting option is available with the following parameters:
- View path centerline: Enables the visualization of the event path.
- This check box is disabled for open loop events without a path.
- View grid graphics: Enables the visualization of the road grid graphics.
- When view grid graphics check box is toggled, road grid parameters can be edited in the Grid Settings tab.
Grid length Defines the length of the road. Enter a positive value in the model units. Grid Width Defines the width of the road. Enter a positive value in the model units. Grid X offset Gives a distance offset to the road graphics in the longitudinal direction. Enter a positive value in the model units. Grid Y offset Gives a distance offset to the road graphics in the lateral direction. Enter a positive value in the model units.
- Road File
- The road file option enables the selection of a road file to be used in the event. The road property file used in this option overrides the road property files used in the Tire entities within the model. The road property file should be compatible with the tire property file that is used in the vehicle.
- Tires
- Using Tire as road selection option, the road file specified in the tire entity is used in the events simulation.
Simulation Settings
- Analysis Parameters
- Define the numerical and output settings for the simulation:
Parameter Name Description Print interval The time step between successive outputs of simulation results. Real-Time Empowered When enabled, MotionSolve builds the FMU of the vehicle and solves it in real-time. Code generation When enabled, the C code for the MotionSolve Vehicle model excluding the driver and tire will be generated. This code can be used to compile and build an FMU, which can be used with any FMU compatible software. For more information see the Parameters: Simulation - Attributes topic.
- Dynamic Settings
- Defines the simulation control parameters for a time-domain-based nonlinear dynamic analysis. For more information see the Parameters: Transient Solver - Attributes topic.
- Static Settings
- Defines the solution control parameters for static and quasi-static analysis. For more information see the Parameters: Static Solver - Attributes topic.
Automated Output Report
| Report Name | Report Signals |
| Steering Input and Acceleration |
| Engine Torque and Vehicle Velocity |
| Vehicle CG Displacement and Velocity |
| Vertical Tire Forces |
| Lateral Tire Forces |
| Tire Lateral Slip |
| Vehicle Slip Angles |
